not work wifi
On the second device does not work wi fi
Configuration two networks. When disabled, the first device wi fi, I can not log in to the second device on wi fi
master config
MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 5.26 (c) 1999-2013       http://www.mikrotik.com/
[admin@MKB_Master] > export compact
# jan/02/1970 05:33:14 by RouterOS 5.26
# software id = DD6H-3P17
add l2mtu=65531 name=bridge_free
add l2mtu=1598 name=bridge_work
add name=bridge_lan
/interface vlan
add interface=bridge_lan l2mtu=65531 name=vlan_10_free vlan-id=10
add interface=bridge_lan l2mtu=65531 name=vlan_11_work vlan-id=11
add authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough \
    group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys \
    name=profile_free supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
    wpa-pre-shared-key=12345678 wpa2-pre-shared-key=12345678
    name=profile_work supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
    wpa-pre-shared-key=p-123456 wpa2-pre-shared-key=p-123456
/interface wireless
set 0 band=2ghz-b/g/n basic-rates-b="" default-authentication=no \
    default-forwarding=no ht-guard-interval=long ht-rxchains=0,1 ht-txchains=\
    0,1 hw-protection-mode=rts-cts mode=ap-bridge name=wlan_free \
    periodic-calibration=enabled periodic-calibration-interval=10 radio-name=\
    MKB_Master rate-set=configured scan-list=2400-2500 security-profile=\
    profile_free ssid=MKB_Free supported-rates-b="" tx-power=18 tx-power-mode=\
    all-rates-fixed wireless-protocol=802.11
add default-authentication=no default-forwarding=no mac-address=\
    4E:5E:0C:53:62:5D master-interface=wlan_free name=wlan_work \
    security-profile=profile_work ssid=MKB_Work wds-cost-range=0 \
    wds-default-cost=0
/interface wireless nstreme
set wlan_free enable-polling=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.11.2-192.168.11.254
add address-pool=dhcp_pool1 disabled=no interface=bridge_free name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=bridge_work name=dhcp2
/queue type
add kind=pcq name=PCQ_Download pcq-classifier=dst-address \
    pcq-dst-address6-mask=64 pcq-limit=500 pcq-rate=10M pcq-src-address6-mask=\
    64 pcq-total-limit=20000
add kind=pcq name=PCQ_Upload pcq-classifier=src-address pcq-dst-address6-mask=\
    64 pcq-limit=500 pcq-rate=10M pcq-src-address6-mask=64 pcq-total-limit=\
    20000
/queue simple
add interface=bridge_work name=queue1 queue=PCQ_Upload/PCQ_Download
/interface bridge filter
add action=drop chain=forward in-bridge=bridge_free out-bridge=bridge_free
add bridge=bridge_free interface=ether5
add bridge=bridge_work interface=wlan_work
add bridge=bridge_free interface=wlan_free
add bridge=bridge_work interface=ether4
add bridge=bridge_free interface=vlan_10_free
add bridge=bridge_work interface=vlan_11_work
add bridge=bridge_lan interface=ether2
add bridge=bridge_lan interface=ether3
/interface wireless access-list
add forwarding=no signal-range=-77
add address=192.168.10.1/24 interface=bridge_free
add address=192.168.11.1/24 interface=bridge_work
/ip dhcp-client
add default-route-distance=0 disabled=no interface=ether1
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
set allow-remote-requests=yes servers=8.8.8.8
add action=masquerade chain=srcnat src-address=192.168.10.0/24
add action=masquerade chain=srcnat src-address=192.168.11.0/24
/ip neighbor discovery
set vlan_10_free disabled=yes
set vlan_11_work disabled=yes
add distance=1 gateway=wlan_free
add distance=1 gateway=wlan_work
/system identity
set name=MKB_Master
/system leds
set 0 interface=wlan_free
slave config
  MikroTik RouterOS 6.21rc5 (c) 1999-2014       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[admin@MKB_Slave] > export compact
# jan/02/1970 06:13:15 by RouterOS 6.21rc5
# software id = U7TE-E1FL
add mtu=1500 name=bridge_free
add mtu=1500 name=bridge_lan
add mtu=1500 name=bridge_work
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n basic-rates-b="" \
    default-authentication=no default-forwarding=no disabled=no frequency=\
    2452 ht-guard-interval=long hw-protection-mode=rts-cts l2mtu=2290 mode=\
    ap-bridge name=wlan_free periodic-calibration=enabled \
    periodic-calibration-interval=10 radio-name=MKB_Slave rate-set=configured \
    scan-list=2400-2500 ssid=MKB_Free supported-rates-b=2Mbps tx-power=18 \
    tx-power-mode=all-rates-fixed wireless-protocol=802.11
/interface vlan
add interface=bridge_lan l2mtu=1594 name=vlan_10_free vlan-id=10
add interface=bridge_lan l2mtu=1594 name=vlan_11_work vlan-id=11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    group-ciphers=tkip,aes-ccm supplicant-identity=MikroTik unicast-ciphers=\
    tkip,aes-ccm wpa-pre-shared-key=p-123456 wpa2-pre-shared-key=p-123456
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=\
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm \
    management-protection=allowed mode=dynamic-keys name=profile_work \
    supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
/interface wireless
add default-authentication=no default-forwarding=no disabled=no l2mtu=2290 \
    mac-address=4E:5E:0C:53:D6:C2 master-interface=wlan_free name=wlan_work \
    security-profile=profile_work ssid=wlan_work wds-cost-range=0 \
    wds-default-cost=0
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool2 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool3 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool4 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool1 ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool5 ranges=192.168.0.150-192.168.0.254
add name=dhcp_pool6 ranges=0.0.0.2-255.255.255.254
add name=dhcp_pool7 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool8 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool9 ranges=192.168.11.1-192.168.11.251
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
set 2 remember=yes
set 3 src-address=0.0.0.0
add bridge=bridge_lan interface=ether4
add bridge=bridge_lan interface=ether1
add bridge=bridge_lan interface=ether5
/interface l2tp-server server
set max-mru=1460 max-mtu=1460
/interface pptp-server server
add forwarding=no signal-range=-77..120
add address=192.168.2.2/24 interface=bridge_lan network=192.168.2.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge_lan
/ip proxy
set parent-proxy=0.0.0.0 src-address=0.0.0.0
/ip service
set api disabled=yes
/ip traffic-flow
set cache-entries=4k
/ip upnp
set allow-disable-external-interface=no
/ip upnp interfaces
add interface=ether1 type=external
add interface=ether2 type=internal
add interface=ether3 type=internal
add interface=ether4 type=internal
add interface=ether5 type=internal
add interface=wlan_free type=internal
/snmp
set trap-community=public
/system identity
set name=MKB_Slave
/system leds
/system logging
add topics=wireless,debug
[admin@MKB_Slave] >
