can someone assist me in this. i dont know what i am missing or doing wrong.
i followed the guide here and was successful to every part BUT i am not sure why theres no connection or what i am missing to make this work.
https://support.nordvpn.com/Connectivity/Router/1360295132/Mikrotik-IKEv2-setup-with-NordVPN.htm
and
https://wiki.mikrotik.com/wiki/IKEv2_EAP_between_NordVPN_and_RouterOS
# sep/01/2019 05:41:54 by RouterOS 6.46beta38
# software id = xxxxx
# model = 951G-2HnD
# serial number = xxxxx
add admin-mac=00:0C:42:B7:A5:33 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=auto \
mode=ap-bridge ssid=A-- wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk group-ciphers=tkip,aes-ccm mode=\
dynamic-keys name=wlan1 supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=xxxxx \
wpa2-pre-shared-key=xxxxx
/ip ipsec mode-config
add name=NordVPN responder=no src-address-list=local
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=ge6.nordvpn.com exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge interface=*8
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=192.168.88.0/24 list=local
add disabled=yes list=n
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid disabled=yes
connection-state=new disabled=yes in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=nord passthrough=\
yes src-address=192.168.88.10-192.168.88.254
add action=mark-connection chain=prerouting dst-address-list=n \
new-connection-mark=NordVPN passthrough=yes
out-interface-list=WAN
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
port-strict mode-config=NordVPN password=xxxxx peer=NordVPN \
policy-template-group=NordVPN username=xxxxx
/ip ipsec policy
set 0 group=NordVPN
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=\
0.0.0.0/0 template=yes
add disabled=yes distance=1 gateway=*C routing-mark=nord
/ip ssh
set forwarding-enabled=remote
/system clock manual
set time-zone=+03:00
/system gps
set set-system-time=yes
/system identity
set name=home
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/tool user-manager database
set db-path=disk/user-manager
