Not working. What am i missing!?
DHCP Clienten is getting an IP adress but devices that are connected to the bridge are not, what am i doing wrong?
add name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] name=ether1_wan
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1
add address=192.168.1.0/24 interface=bridge1 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1_wan
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
Looks ok.
Post full conifg (/export hide-sensitive), maybe something else is interfering.
/ip hotspot profile
/ip dhcp-client
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
Try make the change above
Thanks for your suggestion, but sadly it did not help.
No firwall /filter, nat, etc/ = no internet !
i’ve enabled sourcenat on ether1_wan now but still no work.
Now i reliseade that it’s actully working after i’ve setup sourcenat, but i can’t ping 8.8.8.8 from my bridge?
