Notepad++ (npp) user-defined language (UDL) for RouterOS
I’m not sure how many people use Notepad++, but I think it’s stellar. I write a decent amount of network configs in IOS and JunOS, and I use functions like plugins, tabs, split windows, multiple windows, and especially user-defined languages. As our company moves more into RouterOS I decided it was worth looking into a UDL for it.
Many people create & update UDLs for common languages like IOS, JunOS, Fortinet, etc. So, I found one for RouterOS that someone created a few years ago and made quite a few modifications. See attached if you’d like to give it a shot; I find it helps writing & debugging quite a bit.
To install the file, you need to find your UDL folder.
In NPP, go to Language > User-defined Language > Open User-Define Language folder
(in Windows this is usually C:\Users%user%\AppData\Roaming\Notepad++\userDefineLangs)
Extract the xml file from the rar, into this folder
Restart NPP
Look at the bottom of the Languages list, it should be listed. Now, when you create or edit a file, you can choose RouterOS as the language.
RAR file is also here: https://drive.google.com/file/d/1SKtgiES-2Z4Ji4FubsKOHWM4DUepsJ43/view?usp=sharing
RouterOS-UDL-npp.rar (3.96 KB)
Great thanks!
Thanks !!
@vili11. very nice … Thank You.
I see lots of pretty colours, is that what is meant by ROS language?
