Notification offline devices
Hello.
Is it possible to make an submap notification only if all devices are down (e-mail or pop-up)? Actually when i activate the notification at "Settings > “Polling” > “Use Notification” the alarm goes on when one device is offline.
Thank you.
If your question is still relevant, then I will write detailed instructions here.
Hello Dripke.
It would be very helpful if you could send me an instruction. Thank you.
