Notification Question
Hi, very good job, congratulations.
I have a question, it is possible to run a external program if a device is down?
Thank you advance
Yes. Go to Notifiactions and create the ‘execute’ type notification you want. Once created, you can turn that notification on in any device you want.
In notificatios, if I select type “execute locally or on server” then ask me a command and insert variable.
What I should put there to run an external program, for example, if node 1 is down run calc.exe
Thank you in advance for your help
Apologies if this has been covered in a past topic, but could someone please provide the syntax for running an external application when a device goes down. i.e. I want a batchfile to run locally when one of my web services stops responding.
You’ll find your answer two (or three) items above your own, within this same topic!
Just play with it a little.
Ok, thought there might be some sort of syntax for the command, obviously not :wink: ok thanks.
