Is there a way to get an email when the UPS switches to battery from the line power?
I am using 3.16 and the UPS package. It monitors just fine but I need to be alerted without having to eyeball at dozens of Winbox windows.
you will find the scripts on the follwing links
http://wiki.mikrotik.com/wiki/UPS_scripts
or http://www.stone-rich.at/dl/str-ups/default.htm
Awesome!
I’d be able to find those on my own if Special:Search on the Wiki existed.
one think is that there is search, the other is that you do not know hot to use it.
write in word (case sensitive) you are looking for and wait a moment, then you will be provided with results.
but thats not how teh search is intentionally integrated in the wiki-software you use ![]()
simply fixing the specialpage would be way easier, as waiting for the results is not really intuitive and stops potential users from using the wiki if they can’t search.
the software is used on many homepages and people widely know, that there should be a special-search page, so if isn’t there they think there is something broken and ask in the forum. in the time the “special” search function with waiting is explained you could also have fixed it and would never be bothered. ![]()
