Everytime I try to test the email notifications I get a return “OK” from the dude, but the emails never go through. After further troubleshooting it appears the dude is attempting to connect to my mail server on TCP 465 (SMTP-Auth) but there are no parameters for SSL/TLS or authentication in the dude…
Is this a known problem with beta2?
Doing a tcpdump on the mail server i see no attempt of any connections on TCP port 25, just TCP 465, and torch on the mikrotik device running dude shows the same…
Anyone else having this issue?
This is using the 4.0Beta2 for ROS. Email notifications work fine from my windows installation, its just the RouterOS package that is exhibiting these problems.
