I appreciate the response… but if my SMTP server goes down, then I have no way to get SMS messages.
There is an applicationo that will send SMS directly via USB/Serial modem. However, it needs too monitor a folder for text messages. If a message appears, the application will parse the message, format it, dial the TAP number via the modem and I’ll be alerted of the problem within minutes.
So, what I need Dude to do, or someone to assist me… how do I make a notification that will create a text file with the parameters and save it to a folder outside of the dude installation directory?
create it:
just put 1 line echo %1 >> c:\myfile.txt
in C:\dudescript\echo.cmd
paste XML in your notifications
<?xml version="1.0" ?>
24
2443445
Echo to file
7
C:\\dudescript\\echo.cmd "Service [Probe.Name] on [Device.Name] is now [Service.Status] ([Service.ProblemDescription])"
