Notify when route changes
Hi
i have two default routes (to the internet) on my mikrotik. When the primary route goes offline the routes switches automaticaly to the second. This works fine.
I am looking for a way to inform an external system about the change of the default route. Is this possible with mikrotik? Perhaps using SNMP, MQTT, or HTTP Request? As i see mikrotik does not even log this route change in its own logfile.
BR
mode
You can play around with logging rules, i.e.
/system logging
add topics=route action=memory prefix="Route Changes"
This helped perfectly. Thanks a lot.
To give someting back here my solution to find out the active default route
In Mikrotik: Add a log action (type=remote) with ip destination from a host, where NodeRED is running. Use Option BSD Syslog. I used Port 20514
Add a log rule to send all “route” logs to the new log action. Then you are done on the mikrotik.
In NodeRED this flow will extract the comment of the active route, when it changes:
        "id": "743ea3c6.a7384c",
        "type": "tab",
        "label": "Mikrotik active Route",
        "disabled": false,
        "info": ""
        "id": "2ee0f510.7df702",
        "type": "syslog-input",
        "z": "743ea3c6.a7384c",
        "name": "syslog",
        "socktype": "udp",
        "address": "",
        "port": 20514,
        "topic": "",
        "x": 360,
        "y": 300,
        "wires": [
                "b980ea19.91ba28"
        "id": "7ed62eb5.61b06",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1030,
        "y": 300,
        "wires": []
        "id": "b980ea19.91ba28",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "array",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "1",
        "count": "",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "num",
        "reduceFixup": "",
        "x": 630,
        "y": 300,
        "wires": [
                "1e1a90cb.979067"
        "id": "1e1a90cb.979067",
        "type": "function",
        "name": "",
        "func": "var state = 0;\nvar ret= {\"payload\": undefined};\n\nmsg.payload.forEach(function(element,index){\n    switch (state) {\n        case 0:\n            if (element.msg == \"Select route\"){\n                state++;\n            }\n            break;\n        case 1:\n            if (element.msg.includes(\"comment\")){\n                state++;\n                ret.payload = element.msg.trim().replace(\"comment=\", \"\");\n            }\n            break;\n    }\n});\nreturn ret;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 640,
        "y": 380,
        "wires": [
                "7ed62eb5.61b06"
