I have a RB433AHU with a Verizon Novatel USB727 that is shown and I can do ati commands to it but no matter what channel I use for data/info, all I get are:
status: “unknown”
pin-status: “ERROR”
functionality: “unknown”
gprs-mode: “”
manufacturer: “unknown”
model: “unknown”
revision: “unknown”
serial-number: “unknown”
current-operator: “”
signal-strengh: 192
This is in 3.30 or 4.2. Wiki says the card is supported as of 3.13 I believe. ATI responds fine though. Would I need a correct init string to do the info 0 prompt?
[admin@MikroTik] /interface ppp-client> /system serial-terminal usb2 channel=0
[Ctrl-A is the prefix key]
ati
Manufacturer: NOVATEL WIRELESS INCORPORATED
Model: USB727 VERIZON
Revision: m6800B-RAPTOR65_V-124 [Apr 24 2008 18:00:00]
ESN: 0x5B7020D5
+GCAP: +CIS707-A, CIS-856-A, +MS, +ES, +DS
I believe i have the correct channel (data-channel 0 and info-channel 0) as ATI does not respond on any other channel nor does info. I’ve tried to scan on all channels and never see anything. The card does work fine in Windows though.
