I am reading this thread and I am seeing impending doom (only to a few).
Many raised points are valid:
- not designed for that - per say
- dual-stack
- dynamic allocations
- avoid IPv4 issues
It is like creating an engine with sprockets in which production has a loose variance allowance. Normally that works, but adding two sprockets from the very far end from variance can either stop engine as it will block, or it will spin without even touching each other teeth.
I will post my perspective:
- I donât like dynamic allocations, but I understand why it is done. Removing dynamic allocation will fix the issues for the very few and create issues for many, many more users. We are here quite an internet savvy but think about guys who want just to plug-and-play. Who should give them support to set up static IPv6 prefixes in multiple different routers? We are minority
- Dual-stack argument is BS. I am based in the US. T-Mobile US mobile carrier (not mine, just to show the point) is IPv6 only with NAT64 - not always working properly for IPv4 - huge issues with IPv4 wireguard only. My home ISP (Verizon FiOS) is deploying now dual-stack but large portion of the network is IPv4 only. Internet savvy people will go for HE.net tunnel but again - this is a very, very small minority
- What I would love the most is own /48 prefix with the possibility of moving this between ISPs. Similar to MNP (Mobile Number Portability) - I can pay for this (i.e. $2-5/month), but it needs to work. This is also minority of users.
- I travel a lot so ability to have wireguard at homeâs router is very important to me. Hence dual-stack and ability to connect via IPv4 or IPv6 is super extremely important for me. I work in the industry which does not allow to use VPNs and we are locked into country specific IPs (fin-tech - Big 4 banks). Some of my travel is accepted but with the caveat that I will connect to work from home IP range. Again minority
- Having all of the above issues/problems/perspectives - NPTv6 with ULA translated to GUA is crucial for me. Paying $200 more to get business service with my ISP does not make sense. Either we want to be trailblazers or followers, and that makes a big difference for me. If I have to change the hardware to something else - I will. Just donât kid around that this is ICT grade stuff.
