nRAY initial configuration problem
I have 2 new nRAYs and I can’t get them to connect with eachother. If I have them 1m apart or 10m directly aligned and still no connection. If I scan 60 GhZ network with both of them, nothing is showing. I upgraded them to 6.48.1. I tried with default configuration (plug and play) and manual configuration. Is there a firmware problem or what? How can I enable logging for 60 ghz wifi? Wireless logging shows nothing.
Regards
These should work straight out the box
Check that one unit is setup as a Bridge and the other is station bridge
The Station bridge will be the only one that will find the (AP) Bridge with a scan command
I hope that helps a little
Regards
Paul
