I have two routerboard 532 with four minipci sr5.
I´d like to create a point to point link by wds and ns streme.
I´d like to use a link to receive all traffic and the another link to transmitt all traffic. Is it possible??
Actually it´s working in bridge mode (WDS) throught wlan1, but I´d like work throught wlan too.
I think your looking for Dual Nstreme. If I’m understanding you.
Dual Nstreme is for point to point links. It uses one card to transmit and the other to receive.
I have a link setup link this that gets 45mbps up and down at the same time (ie.fullduplex) which is 90mbps total.
The setup I have in running to ROS on PC systems not the rb532s. I think it work but the speed you would get from it would be very low because dual nstreme takes a lot of CPU power that the rb532 doesn’t have.
I’m hoping MT will comeout with a new board that can handel this.
