NSSA
just one short quation. Using this rule for protection NSSA,i got to two MT.
routing filter
add chain=ospf-out prefix=10.0.0.0/8 action=accept
add chain=ospf-out prefix=172.16.0.0/12 action=accept
add chain=ospf-out prefix=192.168.0.0/16 action=accept
add chain=ospf-out action=discard
and also
add action=accept chain=ospf-out prefix=10.10.3.0/30
add action=accept chain=ospf-out prefix=0.0.0.0/0 prefix-length=0
add action=discard chain=ospf-out
add action=accept chain=ospf-in prefix=10.10.3.0/30
add action=accept chain=ospf-in prefix=192.168.137.0/28 prefix-length=29-32
add action=discard chain=ospf-in
(from Tomas Kirnak)
How many address its hiding, on my case this rule hiding just one address.
Thanks.
in regards to the routing filters..
When you define them with a prefix such as in section # 1… then you will only have an exact match ..
e.g. add chain=ospf-out prefix=10.0.0.0/8 action=accept …will only accept 10.0.0.0/8 prefix nothing more nothing less
add action=accept chain=ospf-in prefix=192.168.137.0/28 prefix-length=29-32 … actually prefix-length should be=28-32 … this will accept anything 192.168.137.0/28 or larger including single ip’s in this range.
Thanks for reply
Actually this topic is last question about NSSA. The main thing will be how NSSA decides which gateway will be allow. I made simulation on GNS3 it’s working all good, but how NSSA decides…i have no idea.
Thanks again
