Nstream Bug on 2.9.14?
Hey folks,
I just receive my first pair of RB500, Im currently testing them with CM9’s
Im using WDS mode and Im bridging to the eht interface.
As soon as I activate Nstream, I loose conection… is this a bug?
Gino
Hey Gino. Did you resolve this issue? Have you had a chance to test the max wireless throughput?
why don’t you simply upgrade to 2.9b16 where there is no nstreme bug?
Actually they are running b16… My mistake. These are fresh rb500 units direct from mikrotik
Gino
ok - if you have any trouble with b 16, send supout.rif to support with full descrition of problem
