Nstream dual?
Is there somehwere on this site a guide on how to set this up?
I search all around but all i find are people talking about it but no real examples/instructions.
Somebody want to point me in the right direction?
Come on folks, there’s plenty of people on here running this so where’s the guides at?
I thought it was pretty self explanatory but it sure ain’t working so I must be over looking something.
Have you checked the RouterOS documentation? They have an application example of nstreme dual here http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php
yes, joie,
mikrotik documentation contains much more you need to set it up.
Thank you, I knew it was in there but everytime I searched for it it came back “no results”.
Must have not been holding my mouth right when I did the search.
Ok, so I think have it set-up like the example but it’s not working, so I guess maybe I am over looking something.
It’s Monday morning and it’s one of them days so here’s my config incase I am overlooking something in the settings.
First Radio;
[admin@NS-1] interface wireless> print
 0    name="wlan-Bottom-RX" mtu=1500 mac-address=00:0C:42:18:AB:8F arp=enabled
      disable-running-check=no interface-type=Atheros AR5413
      radio-name="NS-RX" mode=nstreme-dual-slave ssid="NS"
      area="" frequency-mode=manual-txpower country=no_country_set
      antenna-gain=0 frequency=5180 band=5ghz scan-list=default
      rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
      basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
      periodic-calibration=default periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
      wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25
      hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
      compression=no allow-sharedkey=no
 1    name="wlan-Top-TX" mtu=1500 mac-address=00:0C:42:18:B9:C3 arp=enabled
      radio-name="NS-TX" mode=nstreme-dual-slave ssid="NS"
      antenna-gain=0 frequency=5825 band=5ghz scan-list=default
[admin@NS-1] interface wireless> nstreme-dual
<reme-dual> print
 0  R name="nstreme-1" mtu=1500 mac-address=00:0C:42:18:AB:8F arp=enabled
      disable-running-check=no tx-radio=wlan-Top-TX rx-radio=wlan-Bottom-RX
      remote-mac=00:0C:42:18:AC:20 tx-band=5ghz tx-frequency=5180
      rx-band=5ghz rx-frequency=5825 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      framer-policy=exact-size framer-limit=4000
Second Radio;
[admin@NS-2] interface wireless> print
 0    name="wlan-Bottom-RX" mtu=1500 mac-address=00:0C:42:18:AC:20 arp=enabled
                          54Mbps
 1    name="wlan-Top-TX" mtu=1500 mac-address=00:0C:42:18:AB:0F arp=enabled
[admin@NS-2] interface wireless> nstreme-dual
<reme-dual> print
 0  R name="nstreme-2" mtu=1500 mac-address=00:0C:42:18:AC:20 arp=enabled
      remote-mac=00:0C:42:18:AB:8F tx-band=5ghz tx-frequency=5180
switch the frequencies of one unit and it should work (rx tx)
unit one RX needs to be unit two TX
steven
Yeah, I’m a bone-head, I knew that had to be reversed but I have no idea how I missed that.
Least I only spent a good hour overlooking the obvious.
Thanks mate.
