Nstream Jitter
Hello
I find with nstreams much better for speed and it keeps the pings low when under load.
The links to seem to have more jitter tho
Is this because of the polling?
Its ok if we take the good with the bad but it would be cool if pings were lower.
Any Thoughts?
we have 40-60ms with 20ms jitter for those Ap who have 30-40 clients.
We need to lower this latency and I think the new v3 could help in two ways:
  1. avoiding the use of wds by configuring the client as pseudobridge;
  2. not letting the bridge traffic passing the ip firewall.
Hope it will be stable soon.
Any other suggestions from big network’s manager?
Regards
Rosario
Does WDS make jitter?
it makes latency
what do you mean by jitter???
can we set a specific jitter value?
I am trying to get TDMoIP to work with mikrotik radios but cannot get voice thru, we do not get any PCM-31 signal for voice.
Did you try set up an Eoip tunnel from end to end ? I did that with Tdmoip for voice and it worked well
will try doing that, thanks
also let me know what kind of TDM O IP you use, if you could send me some setting of TDM and radio it would be vey helpful.
thanks in advance
