Nstream & Polling
I now run a 100% rousteros network
I am wondering should I take advantage of nstream & polling on all my radios, even the CPE’s?
Thanks :slight_smile:
Depends entirely on what you want to accomplish.
After doing hundreds of rounds with Airopeek NX i do see the areas where it has an advantage, but also where it’s not an advantage.
Nstreme is a trade off in one set of advantages to improve others.
Thanks Sten.
I knwo teh advantages
Longer Links
Harder to stiff?
More clients per CPE with polling?
Whats would the downsides be?
Higher CPU
Slightly higher pings
Anythink else?
