Thought you guys would like to hear something positive about Nstream.
Setup:
35 mile shot, small hill to a mountain top.
50% Fresnel zone blockage (another, smaller, mountain is in the way).
5.8Ghz
6ft dishes on each end.
No amps.
Almost no noise.
60ft of 1/2in hardline cable on each side.
We first tried Trango (T-link10), no link at all, even without the hardline.
Then we tried WiLan, got a link, but with a very high BER, >90% packet loss.
We were afraid we would need to get an Orthogon or Redline link, but decided to try Nstream with CM9s first.
And… it works, amazingly well.
The signal level is not good (-85 on each side, we still need to do something about that), but it is stable at 12Mbps over the air data rate.
No appreciable packet loss (lost about 50 out of 100000 1400-byte pings, overnight).
TCP bandwidth-test gives us 5.2Mbps, in both directions, simultainiously (it gives us about 9Mbps either way, with uni-directional tests). Extermely stable speeds, less than 100Kbps in fluctuations.
Latency without the bandwidth-test running is always 1ms or less; with the test running it varies between 27ms and 32ms. Wow!
Simply amazing. I can’t wait to see what this link does when we get the signal levels up to a resonable level.
BTW, the exact same system, with Nstream off, gave us speeds that fluctuated between ~200Kbps and ~2Mbps (in one direction), latency between 5ms and 2500ms (without the bandwidth-test running), and ~5% packet-loss on 1400-byte pings.
Nstream rocks, thank you MikroTik!
