nstream2, other than wireless?
Hi…
Have a bit of a question, kind of just wondering at this stage whether it will be possible or not… 2 sites, 2 ADSL lines on one side, diginet with static IPs on the other…
If I establish 2 OVPN or IPSec (with eoip) tunnels between the 2 sites now, is there a way that I can use one tunnel for TX, and one for RX? The idea, is to just like nstream2, use to async lines to create 1 virtual sync line. We are talking low traffic here (256k at most), so I’m not TOO concerned about converting the async to sync, but it would be feasable to do so in the longer term considering growth. So if I can standardise somehow on converting these two pipes to a sync link, it would be good…
Would appreciate anyone’s feedback and thoughts about this. If needed, I’ll draw some diagrams up.
