Nstreme (1) with RB500 and RC7
I want to establish a P2P-Link between two RB500 at 5 GHz. Each Board with AR5413 Mini-PCI-Cards.
For testing, I configured the first RB500 as bridge and the second RB500 as station. Everything works fine.
But If I turn on Nstreme on both Router, the link cannot be established anymore. Log shows an authentication failure, but I did not change any authentification-settings.
After turning Nstreme of on both routers, everything works fine again.
Is there a Nstreme-Limitation for RB500-Boards because of not enough CPU or RAM?
Thank you in advance.
Stefan.
Hi Stefan
It works for me … i have that setup to. Try the new Wierless.NPK file.
then you have more speed.
Okay I´ll try new wireless-package.
