NStreme 2 Questions
hey List I got a couple of Nstreme 2 Questions:
Any one using Nstreme2 in a PTP setup and turbo mode?
Is Nestreme2 capable of PTMP ?
thanks
Gino
No.
Working great, but You need 1Gbps NIC to use all “power of dual”
7000KB/s Download, 5800KB/s upload via ftp same time!
So you’re pulling aprox 56 mbps down and 46 mbps up…
what kind of cou setup you have?, I was thinking of gettin more like 65 mbps each way…
Celeron D 2,4GHz on Bayfield 865GBFL (test on 100Mbps nic, so few megabits you can gain via changing to 1gbps)
65Full dulpex ? hard to get, but on UDP traffic it’s possible
note that real trafic and trafic via wireless are two diffrent things.
Well I came with that number cause there are users of this forum achieving 65 mbps tcp half dup. using nstreme 1 and turbo … so nstreame2 should yield about the same full dup… well that is my opinion…
Gino
