Does the nstreme protocol provide any better results against interference? I thought someone said that it did (due to different packet headers?), but I searched through the forum and didn’t find anything.
We are running up against 2.4 Ghz phones more and more these days -the kinds that have a base station and multiple handsets and therefor are broadcasting all the time…
That is not correct. Nstreme ‘WAS’ having long ping times (latency) in previous versions (before rc2? or so). The throughput under our test was the same or better than 802.11. The TCP throughput (only one connection) was not good because TCP automatically slows each TCP connection based on latency. If you had multiple connections, you would get the equivalent throughput as 802.11.
Since rc2? or before, we have added a dynamic ajustment that does not increase latency when there are low quality links.
to be objective, I have to say that we tried this with 2.8.27 so John’s statement could be correct. But beware, John is talking about latency and throughput, which are not directly connected to resistance against interference.
Our test was performed this way : 2.4GHz, rooftop with 4 directional antennas and one sector, all using B mode. We intentionally installed another antenna pointing at the same direction as one of the strongest directional antennas there, we basically installed parallel link with existing one separated by 1m distance. Then we used the same channel like the first link had. Using nstreme (exact-framing) we could transfer something around 60kB/s with pings around 900ms (and falling out) on G-mode… switching off nstreme brought us to to 250kB/s and ~100ms stable pings still on G. We didn’t test B mode.
Also, we didn’t try any 2.9rc versions, so this could be outdated test. It was some week ago.
Thanks for the claification. I had read the 2.8 manual and had my entire network on exact size
But… after changing to dynamic size everything improved
I am having an issue where evey morning my signal swings from 75 to 90 and then back again. this was causing the signal to drop and come back again. After changing to dynamic size , it does not lose its connections.. hurray
but the big question still remains. why does signal change? I can see noise going up and down, but without a noise measurement we cant tell.
Signal should never change unless you move the antenna, have a bad radio, or have a tree grow overnight..none of these things occured.. I wonder if Mikrotik is somehow combining signal and noise to come up with signal.. perhaps someone from Mikroitk could shed some light on this matter..
dont get me wrong I LOVE mikrotik, I had a mesh network with 18 nodes and it sucked!!! all locustworld did was tell me my hardware was bad, but after simply installing Mikrotik on the same hardware, my problems went away and my service improved 100fold
but I still have that nagging problem of noise.. I am simply blind to wahtever noise is out there in the MK world.. so this is another plea…
Mikrotik gods.. please help me see noise. or at least shed some light on why you dont.
The reason the signal strength changes is because the Atheros has different transmit powers for each rate. The rate changes depending on the quality of the link and therefore, if the rate is slow, the signal strength is higher.
noise is not a mikrotik problem, noise is part of radio frequency. You will always have some level of noise in any system you use regaurdless of the manufacturer.
As john noted, the signal changes depending on what rate you’re connecting with.. the rates will fluctuate due to a fluctuating signal and uses up valuable resources to reestablish a connection.. Only use the rates you need. If you’re not pushing 24+mbps through the link then you don’t need to associate @ 24mpbs… so unselect the supported rates that aren’t being used. This will prevent your link from renegotiating link speed when the signal fluctuates, and will use less resources to maintain the link.
signal won’t change from -75 to -90 because of datarate change.
oh btw, we tested nstreme with latest rc7. Still my results from 2.8test are supported by latest finding - have to say that this is the least resistant thing (=worst) I’ve ever seen in my life. Standard 802.11b (802.11g) equipment is much faster in interfering area than Nstreme. Seems to me like Nstreme is high-tech toy requiring PERFECT conditions to work properly.
I dont think the rates change by a whopping 15 dbm. I could be wrong as radio math is not my strongest and misunderstanding the specs is a possibility. Just to mention a few reasons that we’ve seen cause that;
Water in antenna/cables. Power fluctuations(!!!). Short circuitting the antenna cables. Chip’s that are failing (remember, most cards out there arent designed to live for more than a few years!! Also alot of it is consumer grade quality and have a very high failure rate) and bad connectors.
I’m staggered to hear that Atheros chipsets doesn’t give SNR or Noise Floor readings.
I would assume any radio does that - at least one older chipsets did I believe.
I’m concerned about how to “fault find” densely located MT setups and sectored base stations, if there is no measurement of noise floor at the receiver.
I read this on another forum.. perhaps it is a clue..
–Quote
It has been discussed that Atheros numbers are reported more like a SNR than a RSSI. The way I understand it, as noise goes up, Atheros cards report that as lower signal, but of course, that may not really be lower signal.
–end quote
yes I can and I will, but it will happen on weekend only. We have to announce link failure to customer first and even with this, perform test at night… My observations so far : we had another radio client exactly in the same direction as the original one, so we tried to connect the new one to the same AP. We got disconnections all the time - connecting and immediately disconnecting, in endless loop. Changing frequency 10MHz up or down solved the problem, client is connected and stable. Problem : interference, there is one close channel (not identical!) used in the second client locality. That’s it.
well now we know why the Atheros shows no noise. I have a feeling the Mikrotik doesnt really care to much about Prism and therefore insnt going to take much time in developing a noise setting that only works on those cards.. it would be a GREAT feature that would probably help out alot.
