Hi Guys
I would really appreciate a little help here if anyone can assist or point me in the right direction.
I have this week come across the multiple NV2 link issue that has been previously debated on the forum; initially I had a PtP NV2 link for my backhaul and then a PtMP running NV2 also, everything works loverly except for TCP throughput…as illustrated below
A < – > B 95Mbps
B < – > C 90 Mbps
A < – > C 20 Mbps
So following the advise on the forums, i’ve updated the PtP link to run Nstreme, which instantly resolves the TCP throughput issue however the link is immensely unstable and keeps dropping 10 - 20 times per hour.
Here is the config on the nstreme link, any advise would be hugely appreciated as I am now having to consider using something else for the PtP and I really would rather not go this route.
add authentication-types=wpa2-psk eap-methods=“” management-protection=allowed mode=dynamic-keys name=cstring supplicant-identity=“” wpa2-pre-shared-key=xxxxxxxxx
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce disabled=no frequency=5300 mode=bridge name=wlan-uplink
security-profile=CConnect tdma-period-size=auto wireless-protocol=nstreme wps-mode=disabled
/interface wireless nstreme
set wlan-uplink disable-csma=yes enable-nstreme=yes framer-limit=3600 framer-policy=exact-size
If there is any further information that I can provide to assist in resolution, please let me know
Mark
