I need to make link for 50km , with dual Nstreme.
What hardware can I use for it ?
I see in the PDF ,that the Wlan,
can be only support Atheros AR5211 and AR5212,
Can I use 2 * RB433AH + 2 * XR2 OR 2 * SR71-A for faster link.
Thanks for help
Gorge
Thanks for help
Gorge
U can use all Atheros cards only why to use Nstreme not NV2?
I need max reliable and throughput , my plan was use the “dual Nstreme”.
What about “OSPF” ?
What is the best for PtP high distance (50km) link ?
Can I used 4 * SR71-A with “OSPF” ?
