Nstreme Dual Imperfections..
R52N, X86platform, but same seen on RB800,600 and 433AH, ROS5RC1
There are few issues in Nstreme duals, some are just design but, still bothers as nobody knows, whats up.
You can see with full load that values od signal levels are very often filled with noise level value.
And there is some system bug, that one side od Nstreme shows neat 65/65mbit (which estimated), but second shows 1/2 value 32,5/65, which should be with half band (10MHz)
Second, more disgusting are throughput loses (causes latency lapses, throughput lapses and by VoIP brings some unwanted issues). This gap repeats each 14 seconds and results are really disgusting. I can improve the loss of throughput power by cancelling slower modulation methods, but it steals me possibility of Automatic speed reduction.
What I spotted is, that if you proceed ping from one side to another side of link with time gap of 1/20s of ping you will get packet loss each 7 secs for aprox 100ms. What is strange, if you use outside routers where you squeezelink between , packages are passing without packet loss, but in these moment are latencies increasing which is really messy.
Any plans for imporvements? Thanks
make the support output file after you see those gaps (latency drops) and send to support.
I sent supout morning
