Nstreme dual Link! How?
I’need help for this Question :confused:
How I’must set my Internal Router to work with nstreme dual link?
Is this right to make nstreme dual I must have 4 Radios, in my case I will use 4 RB SXT ac 28 °, two for downstream and two for upstream, is this right then I’ve a full duplex Link?
My Question is how must I setup the Internal Router behind the nstreme dual link? Bridge two ether ports to divide up and downstream, or is dual wan setup required?
http://wiki.mikrotik.com/wiki/Dual_Setup_with_OSPF
This is just one example.
Thank you I’ve readed the Link! But on the img. they use cards, possivle cards with two wlans on each card, my question is can I use 4 SXT ac devices two mount the dual Link? :confused:
Of course you can, just imagine your SXT’s are wlan cards and set them accordingly. You also need one mikrotik router at each end for the settings.
I’ve just found my first bonding result. Sadly the tutorial no longer exist. I’ve used 4xSXT and 2xRB750GL.
http://community.ubnt.com/t5/Business-Talk/Bonding-2-wireless-links/td-p/194143
Found it : http://wiki.specialistoff.net/index.php/MikroTik%2BUbiquiti:Bonding
It was a better choice for me than full duplex.
I’ve found a better and faster solution; I’ll use fiber óptic cable to get the band from my isp, distance to push the cable is 1800m!!!
Hi Inox,
Don’t you have any problem with bonding in this scenario ?? i’ve never used bonding on real world , but in lab it always is unstable and unreliable ,too many packet loss , specially with link aggregation
would you tell me more about your experience ??
thank you
It worked without any problems for 2 years.
I decided to use fiberglass cable, which cost me 30% more, compared to the quality is much better, I have also the possibility to rent my cable for multi media, IP Cameras, etc. !!! :laughing:
I’do not use other devices, iám only use Routerboards !!! :sunglasses:
