I have a nstreme dual link with rb333’s on each side which keeps rebooting randomly. The link is tuned in at -69 for each polarity. MT V3.2
I reterminated the ethernet on both ends which seemed to have slowed down the frequency the link reboots. My tower climber said that the weatherproofing on the lmr to the dish looked good. The rb333’s are in a nema box 4 feet from the dish.
Here is the configurations:
Tower Side AP:
[admin@pg-sri-pg] /interface wireless> print
0 name=“wlan1” mtu=1500 mac-address=00:80:48:7E:8F:66 arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave ssid=“” frequency=5200 band=5ghz
scan-list=default antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 name=“wlan2” mtu=1500 mac-address=00:80:48:7F:29:1E arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave ssid=“” frequency=5200 band=5ghz
[admin@pg-sri-pg] /interface wireless nstreme-dual> print
0 R name=“nstreme1” mtu=1500 mac-address=00:80:48:7F:29:1E arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:80:48:7E:8F:56
tx-band=5ghz tx-frequency=5220 rx-band=5ghz rx-frequency=5280 disable-csma=no rates-b=“”
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps ht-rates=1,2,3,4,5,6,7,8 ht-guard-interval=long ht-channel-width=20mhz
ht-streams=single framer-policy=exact-size framer-limit=4000
Client Side Bridge:
[admin@pg-sri-sri] /interface wireless> print
0 name=“wlan1” mtu=1500 mac-address=00:80:48:7E:8F:46 arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave ssid=“pg-sri” frequency=5180
band=5ghz scan-list=default antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 name=“wlan2” mtu=1500 mac-address=00:80:48:7E:8F:56 arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave ssid=“pg-sri” frequency=5180
[admin@pg-sri-sri] /interface wireless nstreme-dual> print
0 R name=“nstreme1” mtu=1500 mac-address=00:80:48:7E:8F:56 arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:80:48:7F:29:1E
tx-band=5ghz tx-frequency=5280 rx-band=5ghz rx-frequency=5220 disable-csma=no rates-b=“”
Watchguard is disabled but auto generate support is enabled.
The log only shows: 19:00:06 system,error,critical router was rebooted without proper shutdown (cause 1)
The cat5 run is around 75 feet. I have one cat5 pushing the poe to the device and another cat5 which is used for the data. I swapped these cables also.
The one thing I do notice is that cpu sometimes jumps from 4% to 100% but not usually. Usually the link is around 4% cpu when idle and 14% when pushing 20Mbps udp (mt bw test from client to somewhere else on the network).
As far as I know this problem is only at the tower. The client bridge side does reboot once and a while but it is not even near the same times as the ap.
Any help is appreciated.
