nstreme dual problem
I am running nstreme dual on two 532 boards with cm9s. According to the docs I should separate TX and RX by 200 Mhz. By default the config uses frequency 5180, so I left TX there, and set RX to 5320. I set both radios (boxes) to this. As soon as I change RX to 5320 the radios lose connectivity, if I set both TX and RX to 5180, everything works fine. I have tried this in a number of combinations, but the bottom line is nstreme will not connect, unless TX and RX on both radios are set to 5180.
Any ideas?
Raymond
ap1 tx same fq as ap2 rx
ap1 rx same fq as ap2 tx
Is that what you have set?
Yes, that is what I tried, but at the moment, the only way I can get them to connect is by putting all 4 cards in the two aps on 5180. If I move to any other frequency I lose connection. This is true to even if I change all 4 cards to something like 5780. The second I change them back to 5180, everything works again.
Is this in a lab or in the field? If in the field, it may be interefence on the higher channels…
Sure you are using 5.8GHZ antennas, and not 5.3GHZ?
SMA
If I am using 5.3, it would have been an error by wisp-router. I am not near them right now, but will verify. I am running in a lab environment, with dual feed horn, 29 db dishes, 50’ apart.
Not pointing at each other I hope :slight_smile:
I would start with seeing if you can make a single nstreame work on teh upper channels and go from there
:slight_smile:
