Nstreme Dual & Small Channel
We have a large number of P-P links using Mikrotik with Nstreme and 20MHz channel. We are now interested in running Nstreme Dual with small channel size.
Our object is delivering low jitter 4mbps & 10mbps full-duplex circuits (rate limited by L2TP server) in P-P mode while conserving spectrum.
I think that 5MHz or 10MHz channel pairs split between the 5250-5350 and 5750-5850 bands would be ideal for this use.
Since we do not need high bandwidth I expect RB532 to be sufficient.
Is NStreme dual working with small channel size?
Does anyone have comments on this scheme?
Thanks,
Jon
Is anyone using Nstreme dual with small channels!?!
Mikrotik, can it be done?
I use Nsteame (single) with 5 & 10mhz
I would guess duel would work
small channels should work with nstreme single and nstreme dual too.
