nstreme or nstreme dual for a 25 km link?
Good afternoon,
I’m new in mikrotik wireless althought I use mikrotik for core routers.
Just asking about a wireless link 25 km. It will have correct aerial size in order both ends are at max. modulation (~-55 dbm).
It requires high packet rate (~3000-4000 pkts/seconds) but not too much traffic (< 20-30 mbit in one direction, < 5 mbit in the other).
The question is:
which board to use? rb433 will fit this packet rate?
and which wireless protocol ? nextreme on N-cards (h and v pol.) or nextreme dual (each polarization has a different direction)
Will this work? If there is something better I can do?
Thank you for any any advice,
best regards
Antonio
H+V / 20+20 / NV2
not nstreme dual
RB411AH + R52Hn + LMR900 + Jirous 29dbi double polarization dish.
That can guarantee you (on not noisy environment) @ 23,5Km 100Mbps full duplex.
I usually use LMR-400, instead of LMR-900, It’s easier to find and if the cable is 3 meters long the attenuation is tolerable. For the rest I’m okay with Rextended.
Cetalfio
