nstreme over LAN ?
Hi all
i what to make nstreme but with LAN adapters
i have 4 wireless bridge devices and i whan to use them to build point to point connection and using one for sending and one for receiving on each side of the point to point connection.
Unfortunately nstreme don’t work with LAN adapters
any ideas ?
NStreme is for wireless only… You can use your 4 wireless cards to make an NStreme2 wireless link… Read the documentation about NStreme2 here: http://www.mikrotik.com/docs/ros/2.9/interface/wireless.content#4.13.4
and also read the manual here: http://www.mikrotik.com/docs/ros/2.9/
Regards
i have 4 outdoor wireless devices each with 72Mpbs i just whant to combine them to gain as much as possible speed.
You can get about 30Mb full-duplex with P4 machines… read the documentation, also search the forums it has been talked many times before.
Regards
Nstreme is a radio-level protocol for special radio cards that support it.
It sounds like you have an external Layer 2 radio system linked to your MT vie ethernet ?
If so you want to read the manual on bonding and/or equal cost multipath routing…
