Sorry for bad english.
I have а problem - does not work Nstreme under ideal conditions. And the link works fine in the modes of 802.11 and NV2, mode Nstreme low ratespeed and disconnects (“extensive data loss”).
802.11 mode:
/interface wireless registration-table> print stats
0 interface=wlan1 radio-name="000C42CEA6ED" mac-address=00:0C:42:CE:A6:ED ap=no wds=no bridge=no rx-rate="65.0Mbps"
tx-rate="65.0Mbps" packets=115932,151307 bytes=175051083,228869732 frames=60017,76109 frame-bytes=176032341,230215982
hw-frames=70471,76322 hw-frame-bytes=208585645,232146907 tx-frames-timed-out=0 uptime=2m58s last-activity=0ms
signal-strength=-43dBm@6Mbps signal-to-noise=73dB signal-strength-ch0=-53dBm signal-strength-ch1=-43dBm
tx-signal-strength-ch0=-44dBm tx-signal-strength-ch1=-55dBm evm-ch0=22 evm-ch1=24
tx-signal-strength=-44dBm tx-ccq=96% rx-ccq=69% p-throughput=43538 distance=8 nstreme=no framing-mode=none
routeros-version="5.14" last-ip=192.168.1.2 802.1x-port-enabled=yes management-protection=no compression=no
wmm-enabled=yes
Nstreme mode
0 interface=wlan1 radio-name="000C42CEA6ED" mac-address=00:0C:42:CE:A6:ED ap=no wds=no bridge=no rx-rate="3.0Mbps"
tx-rate="6.0Mbps" packets=275,24 bytes=4263,336 frames=275,24 frame-bytes=4263,192 hw-frames=435,272457
hw-frame-bytes=19923,12533080 tx-frames-timed-out=0 uptime=2m20s last-activity=0ms signal-strength=-43dBm@6Mbps
signal-to-noise=74dB signal-strength-ch0=-53dBm signal-strength-ch1=-43dBm tx-signal-strength-ch0=-43dBm
tx-signal-strength-ch1=-56dBm
tx-signal-strength=-43dBm tx-ccq=61% rx-ccq=64% p-throughput=5156 nstreme=yes framing-mode=none routeros-version="5.14"
802.1x-port-enabled=yes management-protection=no compression=no wmm-enabled=yes
Interface:
/interface wireless> print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:D9:4C:26 arp=enabled disable-running-check=no interface-type=Atheros 11N
radio-name="000C42D94C26" mode=ap-bridge ssid="test" area="" frequency-mode=superchannel country=no_country_set
antenna-gain=0 frequency=5830 band=5ghz-onlyn channel-width=10mhz scan-list=default wireless-protocol=nstreme
rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps
max-station-count=2007 distance=dynamic tx-power=0 tx-power-mode=all-rates-fixed noise-floor-threshold=default
nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled
hide-ssid=yes security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-
12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=enabled
nv2-preshared-key="test123" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=legacy
/interface wireless> nstreme print
0 name="wlan1" enable-nstreme=yes enable-polling=yes disable-csma=yes framer-policy=none framer-limit=3200
When idling increases the counter hw-frames.
The problem in different configurations:
- RB711UA-5HnD + sector antenna MIMO, CPE RB SXT 5HnD, distance 10 meter, 5 GHz
- 2 x RB433 + R52Hn + sector antenna MIMO, distance ~1000 meter, 2,4 GHz.
In the two configurations works fine 802.11 and nv2, does not work nstreme. I can not migrate to the nv2, because he does not support EAP-TLS.
How to fix the problem?
