Nstreme Query
Dear All,
I am trying to have a p2p link of 20 Mbps throughput across 15 km distance. LOS is clear. My planned hardware is RB 433ah + 2 x XR5 on each side. I will use 2 x 30 dbi solid dish antenna per site.
Following are the applications.
1.ERP
2. VoIP
3. Streaming video.
Now my query is: should I use Nstreme for this or use OSPF or PCC to load balance between two parallel links?
Thanks in advance,
Sudipta Kr. Pal
rethink about the equipment, too much power for such a distance.
I think you can make this with less than 100 mW with those antenna.
