Nstreme2 with Bridge Interface.... Bug discovered...
Created a NStream2 link - get it to link up.
Create a bridge interface.
Add ether1 to the bridge on both units.
Add your nstream interface to the bridge.
Look at hosts under bridge.
It’ll pass at the MAC layer - transparently bridging between the two boxes.
Reboot the unit.
Now it does not work.
You have to go back into the bridge, under ports, delete the nstream and re-add it, then it works again.
Basically, from a power up boot, it doesn’t pass traffic thru the bridge.
I hope this is enough information — if not, let me know i’ll be more detailed.
Seeya,
Dave
Do you have any other interfaces in the bridge?
Do you try specify admin-mac-address on the bridge?
The only interfaces in the bridge are the nstream and ether1 interface.
Yes, I have the ether1 mac address as the bridge’s admin mac.
I think someone else may have posted about this, but never answered questions about his config – he was referring to it as “nstream2 does not auto start” or something close to that. His symptoms match what I am seeing.
BTW, this is RC5…
Seeya,
Dave
Yes, we have the same problem on our nstreme-dual bridge with RB333. We temporary fixed it with writing script which disable/enable bridge interface 10s after startup…
I have the same problem with 2 RB333 in nstreme-dual, at the first setting they work but after a reboot nothing :frowning:
I writed a little script, as sad Mapik, i dont know is correct or not the script, but after that bridge disable/enable still not working.
Here is my script:
           delay 10;
           inteface bridge disable bridge1;
           inteface bridge enable bridge1;
In Sheduler:
Run script At: startup
I have upgraded the latest v3.0rc5 software. I hope the bug will be corrected as soon as possible, because I have some important links depending on it.
thanks
best regards,
ronniee
will be fixed in the next release.
We are using this and working fine for us…
/system scheduler
add comment="" disabled=no interval=0s name="bridge-reinit" on-event=":delay 10
/interface bridge disable [find]
/interface bridge enable [find]
" start-time=startup
was released the RouterOS v3.0rc6
can anyone confirm, this bug/error (RB333 nstreme2 not working after reboot) was fixed in this rc6?
thanks
ronniee
yes i can confirm this.
