NTH firewall-marking load-balancing not working - possible config error?
I’m trying to implement NTH firewall-marking load-balancing on my Miktrotik Router. I think I might have an error somewhere in the configuration, as my wife keeps getting disconnected from League Of Legends. Please help save my marriage! :slight_smile:
I have two connections, Virgin Media gigabit 1000/50mbps, and BRSK fibre, 900/500mbps at the moment that I am trying to loadbalance.
I have 10gb/sec connections to my upstairs network and my downstairs PC.
Please let me know if you need any other info.
Here is my export:
# jan/06/1970 12:13:40 by RouterOS 6.49.6
# model = CRS309-1G-8S+
add name=listBridge
add name=dhcp_pool0 ranges=192.168.88.101-192.168.88.254
add name=dhcp_pool1 ranges=192.168.89.3-192.168.89.254
add address-pool=dhcp_pool0 disabled=no interface=listBridge lease-time=10s name=dhcp
add bridge=listBridge interface=sfp-sfpplus1
add bridge=listBridge interface=sfp-sfpplus2
add bridge=listBridge interface=sfp-sfpplus3
add bridge=listBridge interface=sfp-sfpplus4
add bridge=listBridge interface=sfp-sfpplus5
add bridge=listBridge interface=sfp-sfpplus6
add bridge=listBridge interface=sfp-sfpplus8
set discover-interface-list=none
add address=192.168.88.2/16 interface=sfp-sfpplus8 network=192.168.0.0
add address=192.168.89.2/16 interface=sfp-sfpplus1 network=192.168.0.0
add address=192.168.12.2/24 interface=sfp-sfpplus7 network=192.168.12.0
/ip cloud
set update-time=no
/ip dhcp-client
add add-default-route=no disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.50 client-id=1:f2:df:92:71:4f:62 mac-address=F2:DF:92:71:4F:62 server=dhcp
add address=192.168.88.25 client-id=1:80:61:5f:10:f9:d1 mac-address=80:61:5F:10:F9:D1 server=dhcp
add address=192.168.0.0/16 gateway=192.168.88.2
set servers=1.1.1.1,8.8.8.8
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=listBridge protocol=icmp
add action=accept chain=input comment="allow Winbox" in-interface=listBridge port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=listBridge port=22 protocol=tcp
add action=fasttrack-connection chain=forward comment="fast-track for established,related" connection-state=established,related
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=drop chain=input comment="block all else" in-interface=ether1
add action=drop chain=input comment="block all else" in-interface=sfp-sfpplus7
add action=drop chain=forward comment="drop access to clients behind NAT from WAN" connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=drop chain=forward comment="drop access to clients behind NAT from WAN" connection-nat-state=!dstnat connection-state=new in-interface=sfp-sfpplus7
/ip firewall mangle
add action=mark-connection chain=prerouting in-interface=listBridge new-connection-mark=odd passthrough=yes src-address-list=odd
add action=mark-routing chain=prerouting in-interface=listBridge new-routing-mark=odd src-address-list=odd
add action=mark-connection chain=prerouting in-interface=listBridge new-connection-mark=even passthrough=yes src-address-list=even
add action=mark-routing chain=prerouting in-interface=listBridge new-routing-mark=even src-address-list=even
add action=mark-connection chain=prerouting connection-state=new in-interface=listBridge new-connection-mark=odd nth=2,1 passthrough=yes
add action=add-src-to-address-list address-list=odd address-list-timeout=1d chain=prerouting connection-mark=odd in-interface=listBridge
add action=mark-routing chain=prerouting connection-mark=odd in-interface=listBridge new-routing-mark=odd passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=listBridge new-connection-mark=even nth=2,2 passthrough=yes
add action=add-src-to-address-list address-list=even address-list-timeout=1d chain=prerouting connection-mark=even in-interface=listBridge
add action=mark-routing chain=prerouting connection-mark=even in-interface=listBridge new-routing-mark=even passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=listBridge new-connection-mark=even nth=2,2 passthrough=yes src-address-list=!odd
add action=mark-packet chain=prerouting new-packet-mark=AAA nth=2,1
add action=masquerade chain=srcnat out-interface=sfp-sfpplus7
add distance=1 gateway=192.168.12.1 routing-mark=odd scope=255
add distance=1 gateway=192.168.1.100 routing-mark=even scope=255
add distance=1 gateway=192.168.12.1 scope=255
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.0.0/16 port=2200
set api disabled=yes
set winbox address=192.168.0.0/16
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=RouterOS
/system routerboard settings
set boot-os=router-os
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Two points
  1. Very few use NTH, most use PCC for load balancing
  2. If a computer game will determine marriage status, you have bigger problems than router config :wink:
  3. A better solution would be to do failover
    a. where all the computers get access to one internet
    b. your wife gets SOLE access to the other internet
