I have I balance of 2gw and works very well and now I want to put 3 gw as you would nht 230-231-232? this config does not work well some Web does not open exhausted time of delay?
you also need to consider as with most “dumb” web browsers, they wait until all or most of the images and text have been downloaded before rendering.
what this means is you have 3 times the chance of getting one of those parts SLOWLY…and thus holding up the ENTIRE page… unless they are all lines from the same ISP.
i noticed this when i Load balenced my dsl and cable line via the Firewall + new connection state+ Nth example from the wiki. it works great!! personally i’ve found that you are better off using policy routing to shove your high BW guys on one line and put the rest on another…its easier to control the high BW guys this way too.
220 221 222 works for me
Use the example with persistent sessions to avoid this: http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
Eugene
That is a excellent wiki example!
Could it be modified for use with a proxy server?
