Hello Guys,
I am balancing load over two Gre tunnel formed over two LTE/PPP connections.
We are transmitting data via the IPSEC tunnel. We are able to balance the load using the NTh technique in the Output chain and marking routes accordingly.
The failover is also working perfectly. Both LTE can support up to 3Mbs download individually
The issue is when the packets are sent via both gateways we are hardly able to achieve the speed of more than 1 Mbps over both tunnels. But when we are testing the failover single tunnel is downloading close to 3 Mbps. Please Help
Below is My configuration :
/interface ppp-client
add add-default-route=no allow=“” apn=internet1.com data-channel=3
dial-on-demand=no disabled=no info-channel=2 name=PPP-SIM-1 port=usb3
use-peer-dns=no
add add-default-route=no allow=“” apn=Internet1.com data-channel=3
dial-on-demand=no disabled=no info-channel=2 name=PPP-SIM-2 port=
usb4 use-peer-dns=no
/interface gre
add local-address=172.20.64.13 name=“GRE-PPP-SIM-1” remote-address=
55.55.55.1
add local-address=172.24.148.87 name=“GRE-PPP-SIM-2” remote-address=
66.66.66.1
set enabled=yes
add address=10.99.1.1/30 interface=“LOCAL LAN” network=10.99.1.0
add address=10.10.10.10 interface=PEER IP=10.10.10.10
add address=3.3.3.17/30 interface=“GRE-PPP-SIM-1” network=3.3.3.16
add address=3.3.3.21/30 interface=“GRE-PPP-SIM-2” network=3.3.3.20
/ip firewall mangle
add action=mark-routing chain=output new-routing-mark=G1 nth=2,1 passthrough= yes protocol=ipsec-esp
add action=mark-routing chain=output new-routing-mark=G2 nth=2,2 passthrough= yes protocol=ipsec-esp
/ip ipsec peer
add address=17.1.1.1/32 local-address=10.10.10.10 name=“IPSEC PEER” send-initial-contact=no
/ip ipsec profile
set [ find default=yes ] dh-group=modp768 enc-algorithm=3des hash-algorithm= md5 nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des lifetime=1d pfs-group=modp768
/ip ipsec identity
add peer=“IPSEC PEER” secret=cisco
/ip ipsec policy
add dst-address=0.0.0.0/0 peer=“IPSEC PEER” sa-dst-address=17.1.1.1 sa-src-address=10.10.10.10 src-address=10.99.1.0/30 tunnel=yes
add check-gateway=ping distance=1 gateway=“GRE-PPP-SIM-1” routing-mark=G1
add check-gateway=ping distance=2 gateway=“GRE-PPP-SIM-2” routing-mark=G1
add check-gateway=ping distance=1 gateway=“GRE-PPP-SIM-2” routing-mark=G2
add check-gateway=ping distance=2 gateway=“GRE-PPP-SIM-1” routing-mark=G2
add check-gateway=ping distance=1 gateway= “GRE-PPP-SIM-1,GRE-PPP-SIM-2”
add check-gateway=ping distance=1 dst-address=55.55.55.1/32 gateway=PPP-SIM-1
add check-gateway=ping distance=1 dst-address=66.66.66.1/32 gateway= PPP-SIM-2
Thanks in advance for your help
