nth load balancing with unequal speeds Mangle config
Hi people ,
I’m using ver.3 & doing a NTH load balance in 2 internet lines ( 1: 2mb , 2: 1mb )
but the traffic from both lines is equal !
I knew that there is a problem with the mangle rules but I don’t know how to solve it :slight_smile:
here is my mangle rules :
/ ip firewall mangle
add chain=prerouting in-interface=lan connection-state=new nth=2,1 action=mark-connection new-connection-mark=conn1 passthrough=yes comment=“” disabled=no
add chain=prerouting in-interface=lan connection-mark=conn1 action=mark-routing new-routing-mark=conn1 passthrough=no comment=“” disabled=no
add chain=prerouting in-interface=lan connection-state=new action=mark-connection new-connection-mark=conn2 passthrough=yes comment=“” disabled=no
add chain=prerouting in-interface=lan connection-mark=conn2 action=mark-routing new-routing-mark=conn2 passthrough=no comment=“” disabled=no
need help …
Don’t use nth. Use PCC.
Can’t NTH be configured to work well with my two line ?
I don’t wanna return to PCC cause it’s not good with the browsing !
Add a second mangle rule for your faster line
so it gets twice as many packets using the nth rules.
I thought of that ,
but don’t know how to set the values ,
(nth=2,1) in line one , will I change it ?
what would be the values in the new added line ?
where are you guys ??
