NTP and 3.22
Hi there,
I upgraded from 3.20 to 3.22 in RB411. I have problem with NTP - I can setup NTP servers(IP) but after reboot there is old values. Does anyone know what is wrong?
Jara
click apply then click ok.
:confused: That is exactly what I am doing. When I set it up the values are still there.. I can close the window with NTP settings, disconect winbox and the vaues are still there. But after restart, the values before upgrade are back again.
wait a minute after reboot, ntp will activate
It is not question of time, but it is question of IP adresses of the NTP. I can change IP adresses, and until reboot it is working perfectly. After reboot IP addresses are back - the previous, from the previous version of MK (3.20)
