NTP Client causes RB493G to hang after reboot (ROS4.17)
I have an issue with NTP Client on RB493G (ROS 4.17).
First of all both NTP package and default NTP Client doesn’t work (i get only “running” message).
But what is terrible, when NTP Client is enabled it causes RB unable to reboot. When I hit system reboot, RB just hangs. After disconnecting power it starts up.
Problem is ONLY when NTP Client is enabled.
Anyone can help with this, or at least anyone has similar problem??
Take supout.rif files and email them to support@mikrotik.com. If the board hangs, the vendor should look at it.
