NTP client if defined by DHCP?
Do I have to configure NTP client manually, if I define the address over DHCP and have a local server?
I see that it is associated and added correctly in client, however I can not remove the addresses.
Apparently, no. Whatever is defined within MikroTik own DHCP server, seems to integrate well with the ROS, NTP server and Capsman included.
