Hope I get this correctly…
I try to configure the NTP client for my RB5009 (running 7.1.1). When entering a hostname (0.europe.pool.ntp.org) into the /system/ntp-client ntp-servers field in WebFig, I get an error (invalid value for ntp-servers).
Entering the same value(s) in Winbox or terminal, works flawless.
Afterwards the “NTP Servers” field in WinFig shows empty boxes, same if I go to Servers where I can see the resolved address but no hostname.
Imho the behavior should be consistent and allow to enter hostnames in both WebFig and Winbox.
Futhermore I’m really not sure, if the current documentation is correct, I was not able to find those settings: https://help.mikrotik.com/docs/pages/viewpage.action?pageId=40992869
