Hi folks,
How do I set the time using the NTP client?
I have the NTP client installed and running, but I can’t seem to find the command to set the time. After a reboot, the NTP client doesn’t automatically reset the system clock.
Sincerely,
Don James
Check here: http://wiki.mikrotik.com/wiki/Manual:System/Time
Which command you use depends on whether you installed the optional NTP package or not.
I installed the optional package.
http://wiki.mikrotik.com/wiki/Manual:System/Time DOES NOT tell how to set the clock using the NTP client.
If you configure and enable the ntp client it will set the time on the device:
/system ntp client set enabled=yes mode=unicast primary-ntp=216.66.0.142 secondary-ntp=69.36.227.90
I changed the ip addresses of the time servers:
enabled: yes
mode: unicast
primary-ntp: 205.196.146.72
secondary-ntp: 108.61.73.243
dynamic-servers:
status: synchronized
Now it sets the time automatically.
Thanks for the help,
Don James
