ntp client stop working?
Hello ,
I’m using on my router ntp 0.pool.ntp.org
and now I have notice it’s stop working …
I get not sync
and after reboot it doesn’t show any data
I have try all kind of ntp server - none of them seem to work
any one know why?
Thanks ,
If you get a non working NTP from you ISP (DNS), turn it off, this may have been fixed in 6.44 beta.
Go to IP->DHCP Client->Use Peer NTP remove the check mark.
Not sure if this is your problem, but worth having a look at.
