Hi, I have hAP ax^3 with ROS 7.16.1. Enabling NTP client in router affects warning message in logs:
WARNING: max permanent peer count reached
I tried few common NTP servers as time.google.com, pool.ntp.org, time.apple.com, time.windows.com but it is always same warning message appears in logs. Deactivation of NTP client resolve the issue.
Any clue how to solve the issue?
You often need to src-nat the port from your ntp-client (So it looks like it’s coming from a high port rather than port 123)
As ISP’s, ntp servers will often block ntp from port 123, (which Mikrotik’s ntp client uses).
How many NTP servers are configured in /system/ntp/client? I don’t know if there’s a limit in RouterOS’s NTP implementation, but I don’t think more than 3 quality servers are necessary (3 is kind of a minimum to form a meaningful quorum).
