Hello guys, I want to know what is the refresh interval of the NTP Client, How can I know if the NTP client is not synchronizing. Gracias.
Hai fren,
make sure your NTP server enabled condition and will show you on connection tracking protocol UDP=123, and set your NTP client and enabled it will started at NTP client status around like this:
- started -/+ 10s
- reached -/+ 40s
- timeset -/+ 30s
- synchronized [your NTPclient handshake to NTPserver]
regards
Hasbullah.com
Thank you!! Good explication man.
