NTP command on RB133c - Upgrade to License 4
Hi guys!
please help me. i read here http://www.mikrotik.com/documentation/manual_2.6/System/NTP.html#zzee_link_1_1037729021
that i can set NTP command to get automatic time from internet. i try to look up but my rb133c do not have this command. i read that i have to get a package ntp-2.6.x.npk on mikrotik but i do not see it. how can I do to install this feature on RB ? thanks
In winbox go to system, packages. Highlight the NTP package and click the enable button. Then you will need to reboot the router. After the reboot, enter your NTP IP address and enable the NTP client and then select your timezone.
Many Tks! i look the submenu, i will try and check immediately! by by Maurizio
