NTP not working
Today I noticed that NTP is not working anymore.
I have multiple devices, all running latest Ros 6.23
All are using the NTP package.
For some of the devices, the NTP status stays on started. On others, it goes from started to reached to synchronized.
On the devices that are not working I’m able to ping the configured NTP servers.
PS. I have a script running every 12 hours to update the IP addresses of the NTP servers. but I can not imagine that this will cause any problems.
it was working fine in older RouterOS versions?
On what boards this problem is happening?
If you use the built in NTP client (not with the ntp package) it works ok?
I have not noticed the problem before.
I have various boards, 1 x RB2011-UiAS, 2 x RB750UP, 2 x RB750GL and 1 x RB951G-2HnD.
The 2011 is not working, and for the 750’s of either type 1 is working and one is not. So I doubt it is model related.
I had problems after upgrading from early version 6s.
http://forum.mikrotik.com/t/sntp-bad-in-6-19/80427/1
RB133, 750 and 751 are all working now.
ive never had problems with it before. What i do is set the gateway RB to sync with the public ntp pool and the set all other RBs and devices to sync with that RB using multicast or unicast.
only one RB needs ntp package, the rest would use SNTP.
